FTR Watts Link (Currently in testing)
Rallim
Bellingham, WA
Interesting. There's a couple guys running watt's links for drifting and they seem to have stupid amounts of grip for it, so I'm definitely interested to see how it looks.
rz5.0
Great state of TEXAS
Well apparently this thread is back, didn't notice until just now. I should have been paying attention, my bad ;)
Since it seems like people are still interested, I'm going to start working on this again. Drew it up in Solidworks so here's a rendering of it as of right now.
rz5.0 ttocs Brian95SVT [MENTION=18765]wmfateam[/MENTION]
Would that use a diff cover as an attachment point to the rear axle?
Enviado usando mi SHP-L710 usando TapaTalk
Pete@FTR
Pete@FTR
Preferred Vendor
Rocklin, CA
Yeah, the plan is to use a diff cover like this, and use the bracing points and lower bolt as attachment points for an aluminum plate with different bolt holes for roll center adjustment
http://m.summitracing.com/parts/str-r5234
Sent from Tapatalk for iPhone
rz5.0
What about the possibility cranking or bolts shearing? Just curious.
I think it was the Saleen watts link. similar design had a lot of issues with bolts shearing.
Pete@FTR
Pete@FTR
Preferred Vendor
Rocklin, CA
What about the possibility of it cranking? Just curious.
We'll find out, I'm going to stress test the crap out it to make sure it's strong.
It's a similar design to what I've seen used in a few others. Some companies machine their own diff cover with integrated mounting holes, but that's not something I'm going to get into right now
Pete@FTR
Pete@FTR
Preferred Vendor
Rocklin, CA
Just looked up the saleen design, they only use one bolt which doesn't distribute the load very well; everything is centered on a single bolt and there is no top plate. The three bolt design I'm using will be a lot stronger
Pete@FTR
Pete@FTR
Preferred Vendor
Rocklin, CA
This just came in the mail, shits about to get serious. This cover has holes for axle braces so they'll be strong enough to use for two of the plate's mounting points.
Pete@FTR
Pete@FTR
Preferred Vendor
Rocklin, CA
Prototype of the plate is coming along. Going to add two more lower bolts for a total of 5 attachment points.
Pete@FTR
Pete@FTR
Preferred Vendor
Rocklin, CA
Got my cover on the way
Nice where did you get it? I ordered thru both summit and jegs and they both had it back ordered so I ended up paying a little extra and getting it from amazon of all places
I don't know if I ever told you, but the fact that you're designing and making parts for these cars has me all kinds of excited and I need to get the project line moving and get to the 95.
Musturd
Nice man ! This is going to be sweet can't wait to see the end result . Do you have any of the tow hooks you designed before left or do I need to order one ?
Carolinastang78
