rick focks
- Joined
- Jan 8, 2007
- Messages
- 13,612
- Reaction score
- 20
:dunno:
Hellion94 said:I'm not sure, Dal.
There are a couple of possible options...
We need to get the car cert'd, but I have no clue when the best time for that would be. There is one of our No Bull Shootouts that's scheduled for ABQ's track on July 28th, And I know we are going to try and compete in that.
We are at the dyno this weekend, and setting up the suspension also this weekend, so that rules this weekend out. The weekend after that, there is something going on, but i'm sure a quick trip to our track will happen.
After that it gets a little hazy. It's possible the weekend of the 14th (or whatever day that will be) we may try to head out to Phoenix to get the car certified and get Brain (my brother) Licensed. That could be a good weekend for a little one or two race match, depending on how the certification and licensing goes. If not that weekend, the next after that would be good to get the car sorted out for the No Bull Shootout, which TRUBBLE has an open invite to attend if he chooses. So yeah, there's not really a plan as of yet.
TRUUBLE said:Hellion94 said:I'm not sure, Dal.
I have points races on the 14th and the 21st. But, I can set you up to get the car certed and put you on a track for licensing either of those Saturdays. If you wanted to do a Friday night thing, we could do that on the 13th or the 20th (unless Friday the 13th freaks you out . . lol).
Dalamar said:Good luck on the dyno, I wanna see the sheet!
What rear suspension is going on the Hellion?
Hellion94 said:Car went to the dyno today.
I guess 530 at the wheels in 95 degree weather with a DA of 7000 ft. and only 12lbs. of boost and 25 degrees of total timing while running rich is a good start. ... It is after all more than a 100 hp more than the car we ran 10.46 in put down... and that 530 was uncorrected....
Edit: I guess I should probably mention that it starts making 500 at 4k rpm....and it made 517 on the last run at only 10lbs of boost @ 5k rpm, then it went lean because our fuel pressure regulators reference popped loose.
Hellion94 said:haha, maybe so. But remember, this was with the big ol' 4 inch pulley and only 12lbs. Give us the little pulley, some more tuning time and some decent air, and then you can see about that 400 shot...
Vendetta said:its sad.. i can't even run a 8.5 in the 1/8th! ??? :-\
Snakebit said:Vendetta said:its sad.. i can't even run a 8.5 in the 1/8th! ??? :-\
:rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: :rollinglaugh: dont feel bad bro, just think how much better your mpg is over Truble and Hellion O0
TRUUBLE said:Well . . . . I'm gonna install one of these:
http://www.nitrousexpress.com/Pages/DomTwinPPAlc.htm
That should make it a close race. :naughty:
