Gearbox removal.
95-stang
Whats the favourite way for getting the AODE box out?
All in one, with the motor, or is it fairly straightforward to drop the box on its own? :help2:
mcaligiuri
if you work on cars it shouldnt take more than a day, i had mine out in 3 hrs ;D, longest part is dropping the h pipe, damn rusty bolts. Drop it out from the bottom. drop the h pipe, remove fleplate to torque converter bolts, drive shaft, cross member, starter, then the 8 or so bell housing bolts, then the biotch comes right out.
95-stang
Thanks, just wanted to make sure its not impossible, so many v8's i've worked on, there's been little or no room to drop the box on its own. :)
