Good set of 4.6 cams..
AaRoN
King Post Whore
Anyone have any suggestions for a good set of cams now that VT is :eek:utofcloset: I was thinking about going with Comp but I'd like someother suggestions and input. Thanks guys O0
Steven
SC
crower FTW, VT engines is dead, but https://www.vt88888888888888888/ is still together and going strong from what I can tell.. these guys are different then VTE.. i'm going with crower stage 2 n/a and there valve spring combo
I would go with Crower or Comp or MPH or Houston Performance...all very good modular cam companies.
Stay far away from VT or VTCEC
Steven
SC
VTCEC as in the link i posted? Tryin to find the crower stage 2 n/a NPI's is a PITA.. there the first i've found yet
Yes, thats not a good company to buy from at this time.
I think Fox-Lake sells crower and so does RPMoutlet...go on crowers website for all the vendors.
Steven
SC
Oh ok, sorry droptop, i dont want me or anyone else to be caught up in VT's massive pile up.. didn't quite understand there situation
mike97gt
Red Deer, Alberta, Canada
anyone using or heard anything about comp 268h? thats what i plan on gettin this winter here but still undecided.
want to keep good midrange power.. dont really want to be revving past like 5800-6000..
Steven
SC
lol i was actually considering those right now.. i'm thinking of going with these instead of crowers.. due to hard press finding the crowers
QTRHRSE
i used 274 comps and LOVED them... VERY ROWDY and pulled like a sum bitch on the top side of 3500!!!!!!!!!!!
that plus ported PI's in 'vert auto went 108.xx in the 1/4 at FULL weight
97stanger
If im not mistaken you can order crower cams directly from their website....it allows you to
I ran the 268H cams for awhile,and they worked well.Not too radical,and the car went mid 12's all day long with those cams,and they weren't degreed(the RH and LH banks were 9 degrees off from each other). I know it had alot more in it too-the converter was too tight,and the cams needed degreeing to make the most power. Now,for the rpm limits you're keeping yourself at-you don't need anything with more than 220* duration. Those cams made good power,they require you to rev the engine to around 6500-6700.
JL
QTRHRSE
^^ yea I def. undertsand that... i revved my 274's to about 6600
and the converter... HAHA i was on the stock converter still.
Never had a chance to get a stall in her... then i parked it to buy my 05 and then tore it down for my 4-valve swap.
Woulda ran much better on about a 3k stall...
You'd need approx a 4200 rpm converter for those 274's. The stock converter is 2400-2600,3000 would be like upgrading from a 2.73 to a 3.08 gear in the rear.
The 268's needed approx 4000 rpm,and mine was a 3500 rpm at the time-way too tight of a converter to launch right.
JL
BigJohnson4.6GT said:
so for comp cams stage 3 npi cams it says a 2000+ stall. Would the stock stall work fine or would you recommed upgrading? http://www.brothersperformance.com/catalog/product_info.php/cPath/1_391_26/products_id/4272
I guess you could say it'd work with the stock converter,but you'd be stupid to leave the stock converter in it. The car won't be any quicker in the 1/4 mile.
Plus it'd drive like ass...no low-end torque=sluggish all around,all the time. That Comp recommendation of 2000+ is a generic note,and doesn't take into account the function of a lockup converter or the lack or torque for the 4.6L's.
JL
Srchop16
