Good set of 4.6 cams..
Steven
SC
that would be an issue i guess with aftermarket cams and a auto.. thats a issue now sadly.. would 262 be better for a daily driven car
Yeah,the 262 would be a good DD cam,but to maximize dragstrip potential, even the stock cams can use more converter.
JL
QTRHRSE said:
i dont think the stock converter is 26-2800...
maybe 2200...
I didn't say 2600-2800.
Any more questions?
JL
r3dn3ck
I've got comp 270s on my 5.4 and they're doing pretty well there near as I can tell (dyno run is set for wednesday, then we'll know for sure). As well as they're doing on my motor I can't help but think you'd have to rev a 4.6 pretty hard to get the same kind of results.
I run that cam in my 4.6L,and it completes the 1-2 shift at 6900 and the 2-3 shift at 6700 at the track. Runs through the traps at 112+mph.
JL
QTRHRSE
i dont know how the hell i misread that LMAO
nice info though... too bad im not on that setup anymore
r3dn3ck
Awww burn.T fer me.
6900? Damn... With the piston speeds from the 5.4 I'd planned on shifting at about 5800-6K in general. That works out to the same piston speed as a 4.6 at 6800-7K. I could feel it lean over a bit after 5000 or so when I was doing 3rd gear WOT runs so I figure any higher is wasteful.
Pennywise2
Depends on what your goals are with the car and where you want the powerband
to be.
Custom grind from MPH sounds good give Tim a call.
justinschmidt1
AaRoN said:
to be.
Goals are to squeeze out as much N/A power as I can. All motor ;D
Dont do it with a 4.6
:hammer:
A
AaRoN
King Post Whore
justinschmidt1 said:
AaRoN said:
to be.
:hammer:
I'm not expecting 800hp. I just want an all motor car. And I'm curious to see how much can be pushed out of it without a poweer adder.
A
AaRoN
King Post Whore
I've been trying to do as much research as possible to find to best combo for the most power. Hard to decide what's gonna work best.
Bigjohnson4.6-you have any pics of the back of your stang?
Pennywise2
AaRoN said:
to be.
If that's the case plan on getting any stage 2 cam even
any off the shelf stage 2 cams will do just plan on doing valve springs
too and rev it up high to see the extra power offered by a stage 2 cam.
A
AaRoN
King Post Whore
Pennywise2 said:
AaRoN said:
to be.
Thanks! O0 I had originally planned for the VT stg 2 but now I'm not buying crap from VT.
voidfinger
QTRHRSE said:
i used 274 comps and LOVED them... VERY ROWDY and pulled like a sum ***** on the top side of 3500!!!!!!!!!!!
that plus ported PI's in 'vert auto went 108.xx in the 1/4 at FULL weight
wow, give me some more info :)
Superman3872
