JB's 98 Coupe Build Thread **Motor Plans 8-21-12**
Im with Musturd. Heard more negative things about the aluminator..... everything from bad threads coming out (tranny mounts, timing cover mounts) to early failure.. .. ..
Teksid or Termi.
DropTopPony
South Jersey
Interesting info about the Aluminator, never heard the bad about them but I have a Teksid so not really researching them either.
Honestly if you only want 550 rwhp you can do that with a 2V and 2.6 KB. I'm thinking of getting the 2.8 Mammoth kit so I can have the fastest car leaving the Daycare.
J
After reading in detail on the 4V swap...I may be leaning back to staying 2V and a KB...but still staying with the MMR short block.
I change my mind every day...so we'll see what ends up happening :)
belber095
Ithaca, NY
are you still planning on doing a wire tuck?
Whistler98
Southwestern, Pa
I'm in the same boat with changing my mind. I have been leaning towards just getting a long block from mmr. Not sure about their heads and how good they are? I might just have them put the trickflows on it. I have started a side fund and I guess it will depend on how much money is in there when the motor goes or if it stays together I guess next year sometime.
J
No reason to go 4v really unless you want 1000 hp
I'll be happy with 500+ for sure...I think with the MMR 4.75, some nice heads (Patriot, Fox Lake, p/p PI, etc), blower cams, and a kenne bell pushing decent PSI...I should be able to hit the numbers that I want.
I'm not a "racer" kinda guy...don't really care about 1/4 mile times, or if I have "the fastest car on the streets"...I just want some nice bark, something fun, and something to be proud of when I pop the hood.
justinschmidt1
Ya man. With a setup like that you should have no problem making 500-550hp depending on how wild you get with boost
J
Yea...the short block I'm getting is good for 750hp...so I'll be able to throw a lot of boost at it. Just gotta make sure I beef up my fuel/spark.
justinschmidt1
You should do a low compression piston when you do the shortblock.
You can only run so much boost on pump gas before running into problems with detonation
J
Yea you can order the block with stock, high, or low compression forged manley pistons...definitely going low compression.
justinschmidt1
If I ever go to the track ill probably throw some race gas in mine and crank up the boost a little bit just for the hell of it. :)
That is one awesome thing about being turbo. I can turn the boost up with a twist of a knob.
alleghenyamerican
