July ROTM vote thread
this will run for 3 days.
You guys know the rules:
*You must have 150+ posts to vote or be a supporter member
*Only vote once
*Do not postwhore..
96_SVT_Cobra
Motor and Drivetrain
-built teskid block
--bored 20 over with all the other align honing, stock cobra crank sent out to be rebalanced and polished, manley forged rods and manley forged and coated pistons 9.2:1 compression
-5 angle valve job on b heads along with redoing all the valves, valve guides, retainers, springs, etc with high perfomance parts. then topped it off with FR500 cams
-Vortech T-trim
-custom piping for intercooler with blow through MAF, modified Tial BOV, AFM power
pipe
-BBK o/r x-pipe
-flowmaster catback
-walbro 255 with KB Boost-A-Pump
-60lb injectors
-KB Boost-A-Spark
-ngk spark plugs
-04 cobra radiator
-RPS turbo clutch and Cyn-r-gy aluminum flywheel
-stock t45
-pro 50 shifter
-FRPP aluminum driveshaft
-4.10 gears
Chassis and Suspension
-eibach sportlines
-tocico shocks and struts
-steeda lower control arms
-MM aluminum steering shaft
-steeda STB
-steeda caster camber plates
-sub frame connectors
-10th anniversary cobra brakes with slotted and crossdrilled rotors
-line lock setup
-battery relocated to trunk
Interior
-alpine cd player
-MMR rear seat delete with aluminum back
-spare, jack, and wrench was removed
-hurst shift nob with button for line lock
-led mod to cluster and hvac
Exterior
-all stock cobra body panels
-Ford GT rims, 18x9 18x10
-clear headlights
-LED third brake light
-55w 6000k headlights and fogs
-SS inserts in rear bumper
thats the main things.
95riosnake
95riosnake
Rio Red 95 Mustang Cobra
Engine:
Fordstrokers 347, 10.5:1 CR
Holley SysteMax Intake smoothed and chrome powdercoated
Anderson NA Power Pipe powder coated silver vein
SCT-BA2600 mass air
BBK 75mm TB chrome powder coated
Scat 9000 Cast Steel 3.400 crank
Scat 4340 Forged I-Beam connecting rods
Probe SRS 2618 Forged Aluminum flat top pistons
Probe main girdle
High volume oil pump w/ Canton pickup
Anderson N61 cam
Holley SysteMax heads converted to 7/16" stud mount rockers
Scorpion 1.6 rockers
Comp Cams lifters
Trick Flow chromoly push rods
Billet timing chain
Canton Road Race oil pan
28oz SFI Balancer
28oz billet Steel flywheel
Ram HD clutch
ARP fasteners throughout engine
Ford Racing water pump
Wazee billet pulleys
Chrome powder coated accessory brackets
SCT 4 bank eliminator chip with dyno tune from Lasota Racing
Walbro 255 fuel pump
Russell braided stainless fuel lines
FRPP 30lb Injectors
MSD coil, cap, rotor
Taylor Thundervolt wires
Stainless catch can
Billet Badges one-off CNC billet intake plaque
UPR smog delete
MAC 1-5/8" Jet Hot coated long tube headers
Custom made 2.5" stainless off road X pipe
Borla Stinger mufflers with stainless 2.5" side pipes and Borla tips
342rwhp/408rwtq (mustang dyno with only 2 miles break in on the motor)
Suspension:
Team Z coil overs w/ Koni struts
Team Z tubular a-arms
Eibach Pro Kit rear springs w/ no isos and Koni shocks
Eibach front and rear sway bars
UPR bump steer kit
Maximum Motorsports 4 bolt CC's
SMR rear shock tower brace
Energy polyurethane bushings
UPR Pro Street lower control arms
H&R 1" rear spacers
Ford Racing 10th anniversary front brake calipers
Braided stainless brake lines
Interior:
Corbeau TRS seats
Corbeau 3" SFI Cam Lock harnesses
Corbeau Harness Bar
10th Anniversary cobra CF Shift Knob
MGW Shifter with blue (short) handle
Cluster, radio, and shifter bezels smoothed and painted Dark Shadow Gray Metallic
Chrome Cluster gauge trim rings
Autometer C2 Water Temp, Oil Pressure, Voltage, and DPSS gauges
Autometer dual gauge pillar
Carbon fiber console lid
Bullitt pedals
Steeda billet AC knobs, lock pins, and headlight knob
Stainless HVAC control panel
Billet shifter bezel
Alpine head unit
Boston Acoustics component speakers (completely removed Mach 460)
Boston Acoustics G5 10" sub in custom fitted box
Kenwood 1000w mono sub amp
Taylor battery relocation kit in trunk
Exterior:
Cervini's 2000 Cobra R hood
Redline Tuning Elite hood struts
UPR stainless radiator cover
Carbon fiber windshield cowl
Projector headlights/Clear corners w/ 6000k HID's and Silverstar turn signals
BOI clear fogs
SVO side exhaust skirts
Color matched painted mirrors
97 Cobra rear bumper
96-98 taillights
Billet fuel door with center painted Rio Red to match car
Stainless cobra rear bumper inserts
Billet antenna
Rolled rear fenders
Wheels/Tires:
Ford 18x9.5" Chrome 2000 Cobra R wheels
265/35/18 BFG KDW2's in front, 305/35/18 Nitto Drag Radials in the back
Misc:
Ford Racing 3.55 gears
Eaton Posi
Orangestang
1996 Mustang GT
1 0f 829
Performance Mods:
2001 PI "Bullitt" Engine
JLT Intake Paint Matched
Port Match Upper Plenum
BBK 70mm t/b
EGR Delete
FRPP Shorty Headers
UPR Off Road X pipe
MAC flowpath Catback
Appearance Mods:
Cobra Big Brake Kit
Kaenan S281 Wing
2003 Polished Cobra wheels
foglight mod
Stripe Delete [ lol :la: ]
244 rwhp 280.5 rwtq
1996mustanggt
1996 Mustang GT
Engine:
Stock Iron 5.4L Block
Manley Forged Rods
Manley Forged Pistons
Forged Steel Crank
Stage 3 Ported PI Heads
Custom Cams
Comp High Lift Valvesprings
MMR 7 Quart Oil Pan
HPS 5.4 Hardball'r Intake
C&L Intake Plenum
JLT RAI
90mm Lightning MAF
FRPP A/C Delete
Fuel System:
Walbro 255LPH In-Tank Pump
30lb Injectors
MMR Fuel Rails
MMR AFPR Kit
Ignition:
Screamin Demon Coil Packs
FRPP Spark Plug Wires
Exhaust:
FRPP Shorty Headers
Mac O/R H Pipe
Mac Pro Dumps
Suspension:
MM Full Length Subframe Connectors
MM Lower Control Arms
Prothane Bushings Swaybar/End Links
Eibach Sportlines
Solid Motor Mounts
Prothane Trans Mount
Exterior:
HO Fibertrends Cobra R Hood
2003 Cobra Rims
Interior:
Generic Racing Seats
MMR Rear Seat Delete
Simco Gauge Cluster
Drivetrain:
Pro 5.0 Shifter
MMR RB450 Clutch
5.0 Resto 4.10 Gear Kit
MM Clutch Quadrant/Adjuster Kit
Upcoming Plans....Turbo, T-56 Swap, Bilstein Shock/Strut Package.
95riosnake...not even a question. All the cars are nice...but Rio is in another league.
