Kenne bell
lilj4u2njoy
Forest City, NC
Does anyone here have a kenne bell that's designed for our 94-95 5.0 cars? Do they have a build thread? I'd love to see it and learn some more about it... Thanks
twovalveterror
Dayton, Ohio
I'll see if I can find some pictures of some I've seen over the years. I wouldn't call them pretty, but I like them a lot just because of how unique they are. there isn't really a whole lot you can do to make a sbf look exotic, but a kenne bell will definitely do the trick!
you'll have to wait for others to chime in with personal experience for the other part of your question though.
Twista
^^^ What he say. Onyx does. It doesn't look pretty like the modular setup with a KB, but it gets the job done which is that matters right?
Does he have a build thread : Not sure.
lilj4u2njoy
lilj4u2njoy
Forest City, NC
I have looked but most of his pics the links are broken, I mean it's 3 grand, what all would I need besides what comes with it besides injectors, maf, and fuel pump? That's kinda what I'm curious about and would love to see tons of pics if anyone can find any
OnyxCobra (Ryan) does
Truth. No build thread but the thing was a way bigger bitch than I was expecting. Any questions just ask.
modo
Philadelphia, PA
go onto the corral in the superchargers forum. there are a couple on there and and i know at least one has a sweet custom inter-cooler setup. those guys can get you all the info you would ever need.
edit.... didnt know there was on here.
lilj4u2njoy
lilj4u2njoy
Forest City, NC
Thanks for the pics, looks awesome, so quick run down please, besides what came from Kb with the charger, what else did u need to do? Also would it do well with a stock motor? 100k miles? Any other advice please by all means let me know lol
Thanks dude. I'm not totally sure because I bought my kit used so I ended up having to get a bunch of extra parts. if i saw a list of what comes with a new kit I could probably fill things in for you. I will say it wouldn't clear the fuel pressure regulator without an intake spacer (may be different with the regular inlet). The problem with the spacer is you need a little bracket to mount the snout of the blower up higher along with a taller hood to clear the blower but it looks like you have that covered. Had to get longer bolts to work with the intake spacer, new upper radiator hose, have to move the AC lines over a little by pulling on them, and just had to redo some of the vacuum lines. Also a larger volume fuel pump is a decent idea but you could get a boost-a-pump I think. Should be okay on a stock motor (pretty sure a member on here had an 11psi KB on a stock 5.0 making 300whp/400wtq) but just make sure you get a safe tune with it, the intake temps are high. other than that unless i'm missing some stuff it's just randoms like fuel injectors, colder plugs, maybe a MAF/TB, etc...
Brian95SVT
Chesapeake, VA
I wonder what my cobra would make with a KB at 11lbs.
I wonder if KB is aware of that situation Ryan and provides the parts to make it fit (cept the hood of course)
I even had trouble at first getting the bolt holes to line up, KB said they had no clue why. I asked them about the FPR not clearing the Flowzilla tube, they said I may need to run a remote FPR. i was like orly, thanks. They honestly tried to help, asked me for pictures of it not fitting (as if i was lying or crazy) but they did get back to me and help me try to work through things. Honestly you forget about all the BS though when you feel how it pulls.
lilj4u2njoy
lilj4u2njoy
Forest City, NC
sweet.... i just would think that over 3 grand of parts you would think they would fit correctly no issues.... but i guess thats the whole deal ya know
hottwheels04
With those mods listed in ur build thread, what are you making hottwheels? Just outta curiosity
Not sure what it makes for power now, Im running on an old tune, But last time on the dyno it put down 330rwhp,I had alot of problems with my new setup and still do I have to swap out my injectors from 24lbers to 30lbers, so I can get it back on the dyno and actually get it above 5,000 rpms lol and not run out of fuel lol etc / top end to get "real" numbers lol
