MM vs stangsuspension caster/camber plates
topless95
Just wanting to pick your guys brains about the diff in quality between mm and stangsuspension caster/camber plates.. :TY:
i have stangsuspension.com CC plates on the way as we speak. i dont htink there is too much of a difference and the SS CC plates come with a warentee anyways. ill post again when i get em and see em first hand
SRT Handz
xsoutherngun89x said:
stangsuspensions plates are now a four bolt design handz
Yeah, i just notcied that they made the 94-04 plates 4 bolt..... they used to be 3 bolt like the Fox body plates.
.....The stangsuspension should get the job done pretty good. I dont think you will have any problems with them..... i think i am gonna spend the extra $40 and by the MM plates
yea i coulda spent more but i figured these will work for me. im not gonna be goin to any crazy suspension setups so the SS plates will be fine for my application
98_MustangGT
also i think that that MM c/c plates are double ajustable. im goin with the stangsuspension ones myself.
98_MustangGT
i guess i should have read the description better on the stang suspension plates. :hammer:
Paul
Although there are few products I will say this about...
I would never buy caster/camber plates from any other manufacturer but Maximum Motorsports. I have personally broken a set of Hotchkis and Steeda plates. My road racecar which has full Griggs suspension STILL has MM caster/camber plates on it. Although the stangsuspension pieces look pretty much identical, I would spend the extra $40 for piece of mind.
Paul.
ReplicaR
I'm running Maximum Motorsports CC plates in my car. Never had a problem with them, and will never need warantee on anything.
I've looked at both of MM and SS CC plates, and here are few things I have noticed.
1. Caster adjustment bolts on the SS plates look tiny and would seem like they could get possibly moved under suspension load. Maybe not on the street, but on the track the load is huge.
2. Maximum Motorsports plates look like they have higher spherical bushing mounting point (pictures are a little wierd, I can't really tell for sure), and spacers/shims that will allow the car. When you lower the car, you can switch the shims around to maintain the shock travel, which is vital for healthy and properly functioning suspension. Stang Suspension plates don't seem to have those.
It's only a 40 dollar difference for crying outloud, so why not go for race proven stuff.
ReplicaR
This is what I meant by the shock travel adjustment. The kit comes with two small spacers and two larger spacers per side. When the car is at factory ride height, you have one small, and two large spacers underneath the spherical bearing, and one small spacer on top, just like on the picture bellow.
When you drop install lowering springs, you are supposed to move two small spacers over, so you have one small spacer underneath the spherical bearing, and one small, and two large spacers on top, just like on the picture bellow.
Good info Replica
I'd go with the proven part, not the copy.
put me down for another vote for the MM plates.
HuskerGT
Nebraska
Great explanation, ReplicaR. The pics help a lot with understanding the spacer stacking.
I have a set sitting in my house waiting for it to warm up and all the snow to melt before installing.
Did you install them yourself or have it done? Also, if you did the install, do you have any tips you could share?
The instructions had me going cross-eyed... lol
