???Motor down???
Lebedin8654
Well i blew a head gasket this morning so its time to go to the drawing board. My question is what head gaskets should i use and if i go back with a blower cam like a Trick flow stage 2 or a ABC cam will it help me out/ will i notice a differance thats worth the money? My setup is a S-trim wit a cobra motor, Stock GT40 heads with stock 1.7 roller rockers and a cobra intake, so will my heads flow enough to make the cam worth it?
BigTang
Pick up a cam, its not going to hurt. why not do a quick gasket match on them while they're off?
L
Lebedin8654
I plan on doing some matching and porting while it will apart, what cam is good for boost and tune friendly?
95 svt cobra
Wow that was fast, didnt you just put this on? i would suggest some MLS gaskets, im running the regular fel pro's and havent had a blow out yet
L
Lebedin8654
yea i had a feeling it was about to go i just didnt know it was gonna be that fast i am gonna order the gaskets soon and i am trying to figure out a good cam to go with the 1.7 RRs that are on the GT40s...
LAFENATU
The Crane 2031 is designed around the GT40 Heads and is designed for Boost/Spray - makes great power.
Part Number: 444225 Grind Number: POWERMAX 2031 (FORMERLY COMPUCAM 2031)
GOOD MID-RANGE TORQUE AND HP, DESIGNED FOR USE WITH 1.7 RATIO ROCKERS AND MASS AIRFLOW STYLE F.I. ENGINES WITH AFTERMARKET INTAKE, HEADS, EXHAUST AND CENTRIFUGAL STYLE BLOWER BEST: 5-SPD OR AUTO W/MILD STALL CONVERTER. (50 STATE LEGAL 85-93, C.A.R.B. E.O. D-225-46) BASIC RPM 2000-5500
Here is the cam card: http://www.cranecams.com/?show=browseParts&lvl=2&prt=5&action=partSpec&partNumber=444225
L
Lebedin8654
I havent really thought about crane cams, i mostly hear about trick flow stage 2. does anyone on here run one of these two?
