Very true about taking them far. When I want to crank the rpm I might get the TF, but they will be on another block. I think the TF is a waste on the stock rotating assembly. I just got my heads back from my machinest. I'm running a N/A setup for now in my 97. I had my NPI rebuilt 40k miles ago, so it's getting my PI's on top, and should have around 10.5 to 10.7 CR. The PI's were basically still new with only 32k miles, but I had some things I wanted to do to them. I decked them .040, 3 angle VJ, intake valve face shaved .040, Viton seals, Manley Nextec springs, Ford lifters, factory locks, retainers, and followers. I did some mild porting. Intake side I took out the lifter bump and blended in the roof. Exhaust side had bowl work on the long side radius, and blended into the sides, with slight work around the guide boss. Exhaust runner was opend up .035. A high polish was performed on the exhaust side for build up only. Intake side I left rough. Every port was CC'ed with water, also extreme measurements were taken cause I'm anal lol. I've got just about every measurement tool there is for porting, and about $400 in specific aluminum carbide bits. Around 8 hours total time was spent. Cam #'s are 224/226 .555/.535, 111.5+1.5 LSA, 110/113 centerlines. I'm running a Bullitt intake, it will let me take advantage of the extra rpm the cams will make. Should peek around 6300-6400 RPM. I've done some work to the intake inside by easing the air flow path where everything mates together, there's some cliffs hanging out lol. It will be a stout little NA combo.
Man I want complemnt you on your car, it looks very nicely done I must say. I bet she will boogie on down the road. Plus i love that red on the car, mine is black. I was just reading some of the post and I came across yours and had to check it out. Keep us updated my friend. As soon as the weather breaks i will be starting my build thread. Keep it real brother.
