New member from Ohio
OhioPhin
Ohio
Hello all,
By this Wednesday, I will hopefully be the proud owner of a 1995 Ford Mustang GT/Saleen Replica. Here are the specs:
Suspension and Handling: Maximum Motorsports K Member & Trans Mount, Max Motor Adjustable Caster Camber Plates, Max Motor Full Subframe Connectors, Drilled and Slotted Rotors, Granatelli Upper & Lower Control arms Upper and Lower Front A Arms, Koni Rear Shocks with H&R Rear Springs, Lakewood70/30 Street Strip Front Struts, and Granatelli 300lb front coil over. American Muscle Saleen Chrome Wheels. Engine & Drivetrain: Vortech V2 S Supercharger ''Full Kit'', B103 Cams, Roller Rockers, Elderbrock Performer Upper & Lower Intakes, Be Cool Radiator, BBK Equal Length Shorty Headers, BBK 70MM Throttle Body & Mass Air, BBK II Pipe & Muffler, Diaboport Mafia Air Tuner, 3.73 Rear End, Short Throw Aluminum Shifter, and Aluminum Drive Shaft & Loop. Custom built Sound System, Classic Roll Bar, LED Headlamps, Saleen Body Kit, Saleen Speedster Cover, Satin Black Paint & Vinyl Wrap, Saleen Graphics, and Smoked Chrome Headlights.
Just looking for some info on maintenance, etc. I've never owned a Mustang, or a convertible. And I've never owned a supercharged car. Any info on care/maintenance, etc is appreciated.
Thanks!!
1998cobrasvt
Depending on price all seems good. Just make sure you aren't picking up someone-else's mistakes.. that could be costly. I have the 4.6 im sure someone with the 5.0 will chime in soon. Good Luck!
O
OhioPhin
Ohio
$12995 is what they are asking. Didn't seem too steep to me as long as everything is as advertised.
1998cobrasvt
A little less and it would be a steal. Seems like the right ball park if as advertised and good mileage. Hope everything works out. Good luck
