new to sn95... first time to the track
GThang98
my mods are jlt intake, shorty headers, upr x pipe catless,slp catback, 75mmt/b and plenum, 3olbs injectors, sct xcal2, motoblue underdrive pullies, comp cams 262
my best was a 13.840 @1oomph, on street tires at 28psi, with a 2.2o 60ft
SN95_DropTop
Nice i just went also for my the first time although my times are not as good as yours but good times though :banana:
G
GThang98
not right now but i'm in the process of getting a camera, as soon as i get one i'll post it
G
GThang98
i just got my 3:73 put in just haven't had time to go back to the track.. i'll let u know when i do go
Drew2o2
i believe you had a 3.27 prior however i know little about the modular generations, personaly if i had a motor than spun to 7k from the factory i would have gone with atleast a 3.90 If you ran a 13.8 with a 3.27 you should probably be around a 13.4-13.3 with the new gear provided you can properly launch the car.
Black97GT
My 2v only goes to 6k?
Drew2o2
I never knew that the 96-98 only went to 6k. I was assuming that he was running a p/i intake and head motor which spinns 7k from the factory. If his is just a plain jain 96-98 he has way to big of injectors.
Mustang9668
Even with the PI swap you aren't going to rev to anywhere near 7k without cams and valve springs. Even with that you probably would go much past 6500 rpm.
The highest a PI car would want to go is about 6200 rpm.
96GTPlanB
