ok wth *ps pulley
wayne94mustang
that should do it
you just need to be smarter then the tool and it will come off....lol
for real, i bet you used it wrong
Suspect
Suspect
ATL
:knuppel2: im using it right. a couple turns and its locked?!
Paul
Nothing should thread into the PS pump shaft when you do it. You should only be using the jackscrew, the big nut, the clamshells and the collar.
The threaded insert things are for installing the gear, not removing it. :)
95-stang
I have that same tool from Jegs, i used it on a UK spec Focus last week, it worked perfectly, just make sure its assembled correctly.
Suspect
Suspect
ATL
yup thats how im doing it. maybe ill throw some muscle in it. i just feel like its gonna break something. we'll see.
5.Woahhh
Typically if you feel like your going to break something, then your doing it right! :thumb:
95 svt cobra
just keep at it and it will come off. Mine was on good and tight the first time i took it off, 13 years of road grime/dirt will do that, givit some cock and shell cum
