Opinion on new set up...
96OPALGT
4.6 Pro Modular 2 valve Long Block from DSSracing
PISTONS-
-10cc Dish Naturally Commonly used in Naturally aspirated or NOS applications
HEADS-
-D.S.S. CNC Full Ported New Ford Racing 2V SOHC PI cylinder heads with high spark plug thread count ,Includes .600 lift spring upgrade & oversize stainless valves
CAMS-???
PULLEYS-
-Steeda 4.6L Underdrive Pulleys
-A/C Eliminator Bracket
INTAKE MANIFOLD-
-Trick Flow Track Heat
-Trickflow 75mm Throttle Body
EXHAUST-
-BBK Ceramic Long Tube Headers
-BBK OFF ROAD Shorty H-Pipe
IGNITION-
-MSD Ford Launch Master
DRIVETRAIN-
-Spec Stage 2 clutch
-SPEC Billet Steel Flywheel - 6 Bolt
-Ford FRPP Aluminum Driveshaft
WHEELS & TIRES
-Cobra R 10.5 in.
-NITTO Extreme Performance NT555R Drag Radial (275/40-17)
New to this site but have had a mustang for a few years now, I wanted some of your opinions on the set up. Pretty much want a street/strip car with some decent power and mabey nitrous later on. What do you guys think, What power would i make, and what cam would you guys recomend???
Thanks for all of your input
-96OPALGT
Tbuck07
You'll definantly need a set of cams..With that set up I'm not too sure, but with myself I'm going with Hi-Tech camshafts. I dont know what lift / duration cam you would need with your set up.
96OPALGT
Anyone from here have a DSS motor in their car? I am going to give them a call tomarrow and see what they would recomend for a camshaft, i believe they would install it for me before shipment but im not sure.
blown98gt
sounds like a decent build, if you can ditch the nitto's and get some MT.. with the straight street radials (like the 555's) they have taken them into the 9's... i've got them and i love the MT's
also you've said nothing about fuel...
96OPALGT
Well i talked to Tom at DSS and he had talked me into The Super-Mod longblock instead of the Pro-mod longblock So here are the changes i made, not to sure what im doing for fuel what would you recommend blown98gt
BLOCK-Level 10 Ford Modular Iron block
PISTON SKIRTS-
High Precision Diamond turned piston skirts.
PISTONS-
-3cc Dish, 2V SOHC Commonly used in High compression naturally aspirated or NOS high octane engines. Extreme X Piston Upgrade
HEADS-
D.S.S. CNC Full Ported New Ford Racing 2V SOHC PI cylinder heads with high spark plug thread count [Add $1,300.00]Includes .600 lift spring upgrade & oversize stainless valves
INTAKE MANIFOLD-
Professional Products Satin Typhoon Intake Manifold
BBK 78mm Throttle Intake
96OPALGT
i figure the price is alright compared to the trickflow, but what else is there P-51 and thats about it, what problems have people encountered with PP?
96GTPlanB
