PI Headswap question
sk8erord
oem or aftermarket? cause my prothane polyurethane trans mount is the reason for me figuring out my rear control arm bushings are out lol.
Aftermarket. The prothane say specifically that they don't fit 96-98 GTs.
Sent from my SM-G950U using Tapatalk
You have to buy a poly trans mount for a fox body and the make the holes in the crossmember longer. Or you can get a cobra t45 mount and get a stifflers transmission crossmember.
I believe the 96-98 gt poly trans mount is molded with unicorn blood and apparently the species is going extinct. Animal rights activists won’t let us murder the beautiful unicorns anymore, so we are SOL and have to improvise.
evilcw311
Most Evil Member!
Louisville, KY
Unicorns are wretched creatures anyways. Spreading happiness and sparkly nastiness.
sk8erord
Out with the old, in with the new Maximum Motorsports solid motor mounts.
Solid choice! lol
Their mounts are fantastic quality. Ive got them also and love the way they feel.
You did yourself a favor going solid!
Now dont report back about vibrations!!! Thats just nonsense! Folks want a smooth ride, buy a lincoln!
sk8erord
Alright, I give up - long tube headers are going to wait until I do the k-member. They are just not going in well. So off-road x-pipe it is. Maybe one with high flow cats.
sk8erord
And I get to take them right back off again - because after I installed them, I was looking at the old heads, and realized I missed moving two plugs on the bottom of each head. So now I get to buy new bolts and head gaskets again, and do all the work... again. :embarrassed: I suppose on the bright side, I'm glad I caught it now, instead of when I was done and started up the motor...
What gaskets? If they are felpro permatorques, they can be reused. Usually bolts can handle torquing 2x
sk8erord
Ford OEM from the Ford Performance head changing kit. Same with the bolts.
sk8erord
Is there any way you can access those plugs with the heads on the engine?
Sadly, no. At least the head changing kit isn't too expensive, and I hadn't gotten any further. Ugh, I thought I was being detailed and careful. :(
sk8erord
It's these two on each.
Yea, those headgaskets are for sure one time torque down. Bolts eill actually go a few torque downs.
sk8erord
Easy enough and not too much more expensive to just buy another head change kit. I'd rather be safe, especially for a track car. Got the plugs moved over, swapped the water pump and heater tube in the meantime. New bolts and gaskets will be here tomorrow, so I'll reinstall them then... after one more check over everything, lol.
Hey...if its a dedicated track car, set up the deck surfaces for multiple tare downs. This is where the surface conditions are very fine and the gasket used wont embed into the materials. This way the same gasket can be used multiple times.
sk8erord
Heads are back on with GT40 rockers, trickflow lash adjusters, and stock pi cams, lol. With what I'm running, is there any real benefit to an aftermarket throttle body and plenum? Also decided today that I'm going to do the A/C delete. Save some power and weight.
Isaac cerr
Staff online
