PLZ..... Help i have a question as to why my front wheels are rearward so bad.
I I JUST PUT ON A FULL KENNEY BROWN SUSPENSION KIT ALONG WITH FRAME CONNECTORS AND SWITCHED REAR END OUT TO 01 COBRA IRS. I HAVE EIBACH SPORTLINE SPRINGS ALL AROUND AND NOW THAT MY CAR IS LOWERED THE FRONT WHEELS LOOK LIKE THEY ARE GOING TOWARDS THE REAR OF THE CAR IT HAS BEEN ALIGNED AND DRIVES FINE THIS JUST BUGS THE CRAP OUT OF ME CAN SOMEONE GIVE ME ANY IDEAS AS TO WHAT TO DO. OH AND CAPS IS STUCK SRRY :drunken_smilie: HERE IS A PIC OF HOW IT LOOKS AND YOU WILL NOTICE IT.
MustangChris
Aurora, CO
help us help you.
get us a pic with the wheels straight. Also, get down a little lower so its more of a straight picture. And keep your thumb out of the lens :p
pictures of your suspension set up would help as well. Pictures of your caster camber plates might also help. Although your CC plates arent "causing" the problem, they will show us what the alignment shop might have done to remidy the situation....
without seeing whats under the car, all we can do is blindly speculate...
could be k-member problem. could be a-arm problems. could be a combination of the two.
we need to see it..
these are the pics i could get of the caster plates and with the wheel strait. ill get it in the air to get pics of a arms and k member , someone told me the other day i needed forward a-arms cant find anything like that.
What arms do you have?
Also have you had an alignment done and what are the specs?
vermilion
maryland
ditch those camber plates. get something with more adjustability. i know youre balling on a budget but search the classified for MM camber plates. or double adjustable with 4 bolts.
Steven
SC
Second. I would say it has to do with the A-arms. Also there is a certain amount of slack in K members usually. Check and see if you can loosen up the K member bolts and jerk that bish forward.
I'm thinking it's in the K member/bottom arm mounts.
CC adjustment wont do anything to change that.
If it's not adjustable, i'd send it back.
cantbuytime
I had to massage my k-member forward about 1/2 inch.
IMO- Looks like the a-arms are on the wrong side.
Naptown_Stang said:
what A-Arms? stock a arms it was a rebuilder with a salvage title but i put it on frame rack and everything was within tollerance of chief systems. is it possible to put them on the wrong side.
MustangChris
Aurora, CO
putting a arms on backwards is *probably* possible, but the sway-bar endlinks wouldnt fit.
if your a-arms only have 1 location for swaybar endlinks, and you have swaybar endlinks connected from your swaybar to your a-arm, your arms are on the correct sides.
as its been said, our K-members have a 1/2" of play in them. their is one "pivit bolt" that has 0 play. it is the *TOP* *REAR* (i think) bolt taht holds the k-member to the frame (under the master-cyliner, basically) the rest of the bolts have room to allow proper alignment of the k-member.
without additional pictures, i suggest crawling under your car with a tape measure and start taking a few measurements to ensure that your k-member is aligned properly....
you said it was salvage, so im not sure what will work exactly on your car...
mustangspartan
MN
Venomous96Cobra said:
frame is off! been there my 95 was salvage and the frame was not aligned correctly looked the same way!
x2 I had the exact problem.. Couldnt tell from the upper rail but underneath it was back about a inch bothered the crap out of me...
you were correct on the fram deal i put it on and used different measuring points was off 13 mm pulled and fixd as for the k member im gonna pull that forward a lil bit aswell.
