Pro flow maf off a foxbody
95Fobra
Hey guys, I recently picked up a trick flow intake that came with a pro flow maf off a fox body that’s calibrated for 24lb injectors. Would this work in my car using 24lb injectors? The housing the sensor is on seems to be as big if not bigger than my stock maf. Thanks
yes it will work. But I think there needs to be a change to the throttle cable to go with the fox body TB.
95Fobra
I’m already running a fox style throttle body setup so no worries there, but the maf will work also and let me run 24lb injectors? Only reason I ask is I have a set laying around.
Carolinastang78
