PRO STARS ON A 94 COBRA HELP!!!!!!!!!!1
Julian Moore
badass98svt said:
julian, you don't use hub centric spacers? they have studs on them already
No I used the Bear Spacers, then put three inch studs all around. Don't hold me to this but If I rememebr, when I went though tech at Cecil, hubcentric spacers are a no no. Not 100% sure..I'll see if I can find it in the NHRA rule book.
97cobrasvt
you are correct but on myrear calipers I did have to massage them on the corners just a little it took me about a minute so not bad
97cobrasvt
Snakebit said:
Z28 This said:
97cobrasvt said:
hey I installed a set of pro stars on my 97 cobra on the front you will need a 25mm spacer per side witch you can buy at summit racing and the tires I run on back are the MT DR's 28 by 15 witch is 275.60.15 hope this helps
pics pics pics pics ;D
+1
here ya go
[attachment deleted by admin] SORRY HAD TO CLEAR ROOM
5.0man
I have 18x10.5 saleens on the rear and have no problem at all. I'm running a 295/35-18. I am about to upgrade to a 315/30-18
mike
97cobrasvt
thats because your running 18's not 15's thats the reason I had to massage the rear calipers to make the wheels fit
EdgarR213
