I figured with the car so close to being driveable on a daily basis, i should finish it up to where i can actually enjoy it.
So the rear end, LCA's, UCA's ans UCA housing bushings all came out from under the car. This thing probably had 3" of road grime everywhere, so everything got sprayed down really well with some degreaser and soaked for about an hour. Then the pressure washer came out for a good scrub. Its still dirty, but 99% clean, i'll have to do one more cleaning session tomorrow before the rear end goes back in.
Since everything in the reae was getting replaced, i started to look at the bolts for the control arms. The lowers were Definitely the wrong bolts. Not surprising since near everything in this car done by the previous owners is half assed and wrong. Im REALLY glad its got an essentially stock motor!
So a trip to Ace hardwarw and $60 later, i had the correct 14mm grade 10 LCA hardware and metal lock nuts:
the upper hardware will only reuse the torque box side, the other end is new.
using the UPR housing bushing tool, the rubber bushings wete removed and spherical bushings installed. My only complaint with this, it would of been nice if the internal lock ring for the spherical bushing could of been oriented so the actual bearing could of been removed from the machined housing. Oh well
BTW, the control arms in the background as for sale for a good price. They need new bushings though.
Then the battle box kit came out and got a good coat of etch primer since it'll be a few weeks till these get welded in:
I've got the battle boxes mostly installed, but no pictures, i'll save that for tomorrow.
