radiator help!! Urgent
98vortech
Hey guys i just got my new radiator in and everything hooked up. filled it with antifreeze started it up and it got really hott. FAST. SO i backed it out of the garage and i have to give it a lot more gas than normal for me to be able to go anywhere because it seems like it will die. Then the check engine light came on and my temp gauge was at 225 degrees so i shut it off and quit foir the night...Does anyone know wat i could have done to make it do this??
thank you guys so much for any replies!!
Red96GT
How fast did it overheat? Did you check the oil?
Start with the obvious first.
98vortech
well it overheated after i drove it around the block so about 5 mins. and the oil is pefrect i just changed it... :noes:
cmher18
If just put it in Leave the cap off and let it run
Sounds like u have air in the system. Its normal to get that after changing coolent and stuff.
Red96GT
98vortech said:
are you sure??? cuz i am flippin out!!!
If you've got oil and coolant it almost has to be air in the system. :dunno:
Was the fan running?
98vortech
i have no clue. the car is running like balls. But i un-plugged tha battery then plugged it back up and no light. but still runs weird...like it will choke if i dont ride the clutch ous just to pull it in the garage.. :-\
19mustang95
of course you won't get another check engine light if you unplug the battery since it resets the computer...do you have an Xcal2 or a handheld tuner?
98vortech
k guys i am not getting any power to the fan but i am getting a groung. :-\ so anyone know wat the problem could be???
98vortech
yea the fuse under the hood is good and thats the only one i know of if there isnt one hiddein somewhere..
jeanfltns01
