CC'S95GT
i did my e-brake cable by removing the box but leaving the consol in place. get the rear end as high as you can and let the axle hang. and you shouldn't need to remove the DS either
DESERTCOX05 said:i did my e-brake cable by removing the box but leaving the consol in place. get the rear end as high as you can and let the axle hang. and you shouldn't need to remove the DS either
uncltrvlnmatt said:DESERTCOX05 said:i did my e-brake cable by removing the box but leaving the consol in place. get the rear end as high as you can and let the axle hang. and you shouldn't need to remove the DS either
Fortunately I don't need to replace it. I just need to reconnect it under the console. How does the box come out of the console?
95convgt said:Just rent the tool from autozone or Advance.... It's free and you get your deposit back when you take it back that Cube thing is a PITA. Make easy work and get the right tool the first time.
95convgt said:uncltrvlnmatt said:DESERTCOX05 said:i did my e-brake cable by removing the box but leaving the consol in place. get the rear end as high as you can and let the axle hang. and you shouldn't need to remove the DS either
The rubber pads you see take those out and you will see screws. Unscrew and there ya go.
