Sick man! you wont be dissapointed.
looks like the MM K comes with a bit more adjustment and bolstering than my Griggs piece did, mostly in the back portion where the square tubing is welded to the small round stock. I cant adjust the control arm pickups either, I only have one hole for that.
I'm guessing you already had a bumpsteer kit?
I set my engine back 1" and noticed the rear end actually had grip! in stock location, I noticed the car tried to rotate mid corner, with the rear trying to take the lead, like it was a bit nose heavy. Seems like the new geometry is designed for the 1" setback. And, from personal experience, if you go to have your driveshaft shortened, find someone that is an EXPERT!
