roller cam
cornhusker
Is it better to go with a roller cam or a flat tappet cam? What would the advantage be?
Also with roller cam I would have to change drive gear on distributor correct or the camshaft would get eaten the drive gear off the end of the camshaft and sends tiny particles of metal through out the engine? So I'd have to get a composite gear
modo
Philadelphia, PA
roller is better for longevity BUT that doesn't mean if you have a tappet motor that you should change to a roller. changing over is costly. you only have to use the composite or a bronze (cheaper) gear if you are using a solid lifter (flat tappet or roller) but whatever cam you get it will list what gear is required.
C
cornhusker
Well guy I purchased motor from had told me it was it was converted to roller using a custom ground cam with a small base circle cam and also uses factory Ford roller lifters.
C
cornhusker
modo
Philadelphia, PA
its possible but i would check the lifter valley as they would have had to drill it for the dog bone hold down piece
C
cornhusker
Ya he had talked about a spider plate that has to be bolted to the block to hold the roller lifters from turning as the engine runs.
C
cornhusker
I need to find a small base circle cam can't really find anything good for performance and will sound aggressive any recommendations
