Sept ROTM - Best Engine - Voting
Status
Not open for further replies.
Orange 94
Alberta Canada
Time to vote for September ROTM! This months theme was best engine, so vote for your favorite.
[MENTION=17027]whiplash473[/MENTION] [MENTION=9290]venom[/MENTION] [MENTION=19784]BOOOSTD[/MENTION] [MENTION=16849]KidK9[/MENTION]
whiplash473
Engine break-down:
ALL MACHINING DONE BY ME EITHER IN MY GARAGE OR AT WORK, WHICHEVER SUITED BEST. ALL BODY WORK DONE BY ME IN MY GARAGE. FUSE BOX AREA IS STILL INCOMPLETE.
DSS FORGED AND BALANCED 4.000" 331 STROKER KIT, MATCHED FLYWHEEL AND BALANCER
ALL CLEVITE BEARINGS
SPEEDPRO RINGS
CANTON 7QT
HONED AND NOTCHED CYLINDERS
TFS STAGE ONE CAM
TFS 170 TWO HEADS WITH 1.7 ROCKERS
TFS TRACKHEAT UPPER/LOWER INTAKES
PRO-M 80MM MAF
ANDERSON 4" POWER PIPE
SR 75MM THROTTLE BODY
BBK LONG TUBES
MSD DISTRIBUTOR, COIL, AND WIRES
FORD 30# INJECTORS
venom
-4v 2004 Cobra Iron Block 9.8CR
-3v windage try, Canton oil pan
-Manley 6.5cc Pistons
-Sullivan Intake
-MMR stage 3 port and polish heads
-Comp Cams Custom SC Grind
-Custom Procharger D1 SC plate, reverse mount alternator
-8 rib setup
-Scott Rod Panels
-Custom Cooling system, Crossover and expansion tank delete
-Wire tuck
-Coil pack tuck
-MegaSquirt stand alone ECU, Flex fuel setup
-Magnafuel system, sump tank
-ID1300 Injectors
-Push to connect air lines
-Teflon fuel lines
-Dual Canton Catch cans
-HP level Unknown, Currently self tuning with Megasquirt
BOOOSTD
347 Shortstroke Turbo Motor
(331 Crank/Rods)
-Dart Sportman block
-Forged crank
-Forged Rods
-Forged pistons
-Turbo piston pins
-7 qt oil pan
-Modified oiling system
-Screw in frost plugs
-Custom turbo camshaft
-MLS Head gaskets
-Moroso valve covers
-TFS cylinder heads (CNC Ported)
-Hydraulic Roller lifters
-1.6 Roller rockers
-Victor Jr. Intake (Ported)
-Wilson Elbow
-Wilson Throttle body
-MSD Distributor
-SFI Dampner
-Edelbrock Fuel rails
-60lb Deka injectors
-Billet timing pointer
-70mm On3 Turbo
Mustang Dyno = 605rwhp/562rwtq
KidK9
333 Stroker Engine
Eagle One Forged Stroker Kit
Edelbrock Victor Junior 60cc Aluminum Cylinder Heads Stage 3 Port and Polish
Speedpro 1.6 Aluminum RR’s.
Comp Camps Nitrous HP Camshaft
Trick Flow Upper and Lower Intake
Summit Billet Distributer
60# Injectors
MSD 6AL and Coil
Stainless and Braided Fuel Lines
Billet Fuel Rails
Mishimoto Radiator
All powdercoated and painted HOK Booty Blue and White. Polished and painted pieces throughout.
Status
Mikehonco69
