Shock/Strut Recommendations Please
greenscobie86
The Big Apple
Hello,
I've been searching quite heavily on this topic but I would still like an opinion of the suspension folks here @ SN95Forums.
My 96 Cobra vert is in pretty desperate need of shocks/struts.
I had H&R SS's paired with KYB GR2's and stock Motorcraft shocks(not a wise choice) on my old GT.
With the Cobra I am not looking to go for an extreme drop, but rather a more "touring/mild" solution.
The car will not be getting lowering springs, the only thing that will be done to bring the front end down is a removal of both upper/lower ISO's.
So what is a good set of shocks/struts to use if I'm staying with stock springs?
Would the KYB GR2's/Gas Adjusts in the rear be a good setup?
How about The Tockico Blue's?
My budget for shocks/struts is gonna be around $350~$400 due to the fact that I also want to get ball joint boots/sway bar links/bushings to further refresh the suspension.
Thoughts?
Blind
find some take-off 03/04 cobra bilstein struts for the front, and a set of bilstein HD's for the rear, should be within budget easily.
greenscobie86
greenscobie86
The Big Apple
Ok thanks guys.
So a set of used 03 Cobra struts up front will be the best way to go then? Even for a stock spring rate with no lowering?
greenscobie86
greenscobie86
The Big Apple
Gotcha.
So I guess NO one here has ever used Tociko's?
I am going to stay away from KYB's since I've had them on my car before and they certainly weren't the "best."
Blind
I used tokiko blue's, aka HP before going with bilsteins, and they were no better than stock even with very mild steeda comp springs. I never ran them with stock springs, however.
greenscobie86
greenscobie86
The Big Apple
Ok great! Thats what I really needed to hear. I've never ridden in a Tociko equipped car so I was looking for first hand experience.
adrift
This is a timely thread. I was just considering Tocikos cause I seem to read a lot of people using them around here. Guess I should reconsider.
cntchds
I have Tokico blues (HPs) and I could not like them less. I have very modest Mach 1 springs (Front:600lb/in Rear:250lb/in) and my car bounces all over the road. I am upgrading soon after less than a year with these shocks. Some people can grin and bear them since they probably won't blow with even fairly high spring rates, but they are terrible for ride quality.
I completely agree that trying to find a set used Bilsteins is a great choice, and if some time down the road they need to be rebuilt, it's 50 dollars a piece... Which is a lot better than having to buy a whole new set of dampers.
