Starter problems - strange clicking sound
danielson631
so i noticed my starter was loose and missing a bolt that must have fell out. got a new bolt and tightened it up and when i go to start the car it still makes that clicking noise. here is a quick vid i took turn your sound all the way up..
whats wrong with it do i need a new starter?
or are the teeth on my flywheel screwed or something idk please help me someone thanks
almost forgot the video
YouTube
- Broadcast Yourself.
2slo95fiveoh
Lawrence, Kansas
Re: NEED HELP FAST!! please
Are you sure the other 2 bolts are tight? If i remember right there are 3 bolts that hold the starter.. If they are tight then perhaps when the
starter was loose, it ground down on the starter gears teeth, and now there isn't enough material to turn the flywheel...
In short, check all the starter bolts. If they're loose, retighten and try again. If they're tight, you need a new starter.
danielson631
i needed to go somewhere so i just rolled down my drive way and started it that way when i got home i turned it off and then tried to turn it back on again and it worked perfect. and several times after that.
idunno?
i checked the bolts they are tight the one on the top is not there though.
does anyone know exactly what size/type of bolt i need for this?
i guess i should delete this post cause its usless now
sounds like Thumper the bunny rabbit to me... not the gear grinding on the flywheel. Id replace your starter. Sounds like its not something is seized or broken inside the starter...
danielson631
but it works now so idk im just going to let it rock and when i get time put a little bit of lock tight on the bolts to make sure they stay put.
still wondering if anyone knows exactly what size bolts to hold the starter in place??
use the green locktight. its not as strong as red, but its for assembled-parts, so it will penetrate the threads so you dont have to take the bolts out.
dono what size the bolts are.
sounds just like the problem i was having... would work, wouldnt work. would work, wouldnt work. Time for a change amigo. just do it.. its $100.00 with a $50.00 core return. just get it out of the way... you'll hate yourself when youre stuck in a mall parking lot at 1AM with a car that doesnt start.
danielson631
yeah your deff right i will get to it this weekend. everytime i get in i hope it starts on my return trip haha
mustangshane
Powhatan, Va
Check your flywheel. Mine had developed a flat spot on the ring gear. It sucked but I had to replace the flywheel and starter. Because it chewed the teeth on my new starter. Better to have a new starter and flywheel than to have a bad starter chew up another ring gear. I've been down that road before.
lmfao. it sucks when your starter is dead... and you KNOW its dead.... but you HAVE to go somewhere... and you learn to park on hills for pop-starts.... But what SUCKS is when you stop for gas... perfectly level surface.... forget about your bad starter. turn off the car... all alone... i had to get Ishmale the attendant to push start me. lol.
sure it isn't a dead battery? My truck makes that same noise when it is low...... What is your bat voltage at and how old is it? If you are in a cold climate it will take a little extra current to turn over.
+1. good thinking ttocs, your ttocsin' it up today... thats for sure!
