Stuttering 95 GT
Prdbyford1
My 95 GT has developed a stutter when you are cruising (part throttle) at lower rpms. The engine is smooth as silk while accelerating. It has fresh plugs and wires along with a new distributer, cap/rotor, O2 sensors, and new egr valve. Any ideas? Thanks in advance.
94-427
make shure to check comprestion, may have an injector trying to sut down, also unplug EGR and drive see if problem gos away may have EGR opening to mutch or to soon
give me more info I an ASE master tech I will try to help
MuscleInc1320
check it with a vacuum gauge and let us know what the readings are. my car does the same thing and it cuz i have a vac leak that i havent found yet lol
P
Prdbyford1
LOL mygreengt. I knew that was coming sooner or later when I posted. Going to get some vaccum readings. What about a small hole in the stupid pipe from the egr to the header causing a leak?
MuscleInc1320
that would be an exhaust leak tho not a vacuum leak plus there would probably be a ticking noise in that area when the car is running
