Suspension question
jfor441
As far as the rear lower and upper control arms go, I was watching powerblock this weekend and or last, and on he Musclecar show they boxed the stock control arms.
If the weakness in the stock upper and lower control arms is because they are stamped, how much stronger would they be if I took my welder and boxed them? I have plenty of scrap steel around so that wouldn't be a problem and I have plenty of wire gas for the mig welder.
Opinions?
dapack69
If you are cheap, then yes that is a real good way to improve them from flexing so much, but the rubber bushings are still not helping at all.
98stanggt
nothing else compares to maximum motorsports, try them for control arms spend the extra couple bucks and get the best qualty stuff
Jrgunn5150
I would work, but you would still have sheetmetal in the U part. The boxed ones have thicker metal all around. Now if you have good welding skills, I don't see why you couldn't just buy some rectangle stock and tube stock and make your own anyway.
J
jfor441
Hmmm... You have a point there. My welds aren't bad but it wouldn't take me much practice to get back to where I used to be.
scarface
Guest
jfor441 said:
Scarface said:
the bushing is more of a downfall than the boxed.
Couldn't you just replace the rubber bushing with an aftermarket bushing?
yeah, but for the average person, its much easier to just buy a new control arm then it is to weld, and press bushings.
J
jfor441
Guess I am lucky to access to cool stuff. I forgot most folks don't live out in the country :D
voidfinger
Well i just bought a full bushing kit so i'm about to install them lol, Scar... i'll need a press????? you sure????
Anyway, i heard that you want to keep the factory ones on top or the suspention will bind up real bad and the only thing it will be good for is the strait line.... plus that heavy duty stuff rips the shit out of torqu boxes lol.
scarface
Guest
most bushings need to be pressed in, I think there is a tool you can rent to press them in also ??? I used to always burn out the old bushings, and use a bench press to re instal them.
voidfinger
o ok, well i got a pretty big bench press "i think" its hooked to the work table and looks like a super heavy duty c clamp??? thats a bench press right???
Jrgunn5150
with a big lever on it? If so, then yes it's a bench press. Also, I haven't noticed any binding with my upper urethane joint's. I do grease them all regularly though.
scarface
Guest
thats a vice...however, use ALOT of grease on it, and it may work.
scarface
Guest
same here...everyone tells me there are going to bind, I hit them with the grease gun once every two weeks.
J
jfor441
I LOVE the avatar man! Yoda rocks!
voidfinger
well i don't thing the urothan bushings are the problem. But how do you greese something without a greese fitting???
scarface
Guest
My CA's have grease fittings.
