Schiffy
I was planning on going with UPR solid upper and lowers... along with the QA1 K-member/coilover kit. does anyone have a say so about that?
What do you want to do? Handle better or drag race?? If handling is your thing, spend your money on either the Griggs K or the Maximum K. If DR is your spot, the QA, D&D and others are for that as they focus on front end weight loss more so then cornering geometry.BadBlack95GT said:I was planning on going with UPR solid upper and lowers... along with the QA1 K-member/coilover kit. does anyone have a say so about that?
NYC94GT said:i KNOW, i DID, i PAID.... :behind: But.... the car handles like a MOFO! Better than any setup and I would think on par with Maimium Motorsports.
MuscleInc1320 said:no bro really thanx
NYC94GT said:What do you want to do? Handle better or drag race?? If handling is your thing, spend your money on either the Griggs K or the Maximum K. If DR is your spot, the QA, D&D and others are for that as they focus on front end weight loss more so then cornering geometry.BadBlack95GT said:I was planning on going with UPR solid upper and lowers... along with the QA1 K-member/coilover kit. does anyone have a say so about that?
Here's what I was told from a tech at Griggs... He said the SN-95 and FOX platforms are both plagued with handling issues more due to the REAR END set up than the front end. Yes, the front has problems too, but the "roll center" of the rear is actually in the pavement! Causing the rear end to lift hard during hard braking, and a condition of "snap oversteer" under hard cornering. This is because the front and rear roll centers do not pivot around the same locations. This binds the control arms in the rear as they are asked to do too much! To fix this, you need to remove the upper control arms and install a panhard bar and torque arm. There are other "watts link" setups that will do the same thing so this isn't the only way for the rear end. I know the K-Member and tubular a-arm with coil overs are the "sexy" way to go cuz it looks good. But for limited $$$, spend the money on the rear first. Trust me, your car will handle like it has an IRS setup. Then save your cheese for a bigger brake kit like the Cobra R Brembo set. Then do the front K/C-O work. O0
The torque arm/Panard bar set up will give you a harder launch than the typical 4 link stock suspension on the Stang. You won't need the quads either. Do the rear man, then brakes... you'll be satisfied! I think you can even use the tubular a-arms in the front with the stock K... Saving weight, but u'll have to run coil overs... :naughty:MuscleInc1320 said:well i kno i cant have my car be great at everything lol but i was looking to get a suspension that will me get traction at the track as well as handle better then stock. i dont plan to fly through canyon roads all i want i a better all-a-round suspension. but i understand now that i should focus more on the rear for now until i have the money to work on the front. thanx guys you have been a big help.
Slotted are good. They tend not to stress crack around the grooves unlike the holes. But to say Croos-drilled is a waste is not correct. They just have more drawbacks. I would go with the Cobra R setup, or for less cheese go with the twin-piston Cobra kit. I think it is $500 or so.96sohc said:Slotted or brembo blanks; cross-drilling is a waste of time.
