if you read about my troubles with my air ride in the "tell what you did to your car" post skip down to the **************** line below to save time.
It appears I am fucked on the ridetech air ride controller... The VERY VERY VERY last thing I had to do on my list was to program the air ride height presets before I took it for an alignment. This is important because you have the alignment done on preset #2 and this is normally as simple as getting it to the height you want and then holding down preset 1/2/3 for 5 secs and it programs. The problem is that I had to move 2 of my ride height sensors because the larger wheels would rub them on full turn. This changed the height sensor readings a little and I have never reprogrammed them because it wasn't on the road. Last night I went to go program the settings and it gave me an error about cross psi overloaded or some bs and would not program. I tried to rerun the initial set up to reprogram everything and it locks up and never starts it. Last week I wanted to turn the option off where when you power it up it automatically goes to preset #2 but I wasn't able to. Every time I changed it, and exited the menu it would turn it back on automatically. I called ridetech and talked to them an they said that the version 13 software that is on mine was known to be a bit buggy and also didn't like to be reflashed or updated... At that time it wasn't a deal breaker that I could not turn the #2 on power option off, but now that I can't reprogram the ride height settings I really have no accurate way to get back to the same height so I can drive it after I control it to get it close enough with the only penalty being that I will chew through "19 tires which is a pretty cheap option. When I talked to them last week they said they could give me a deal on a new control system(still not cheap) but the new one uses your phone as a display and then you have button that goes in the cig lighter for the presets. Now knowing that they could not make a hardwired display that could be upgraded/reprogrammed I have no faith that using my phone as display would leave me in any different situation another 5-6 yrs down the road knowing how often I drop and upgrade my phone and that the support for upgrades on these will eventually end. This would also mean I would need to figure out a way to fill the hole in the overhead console I installed and flush mounted the display into and that does not make me happy.
It looks like I have a nice ridetech paperweight that if I use it will make lots of rubber tire paper weights. The idea of having to tear out the old system and then try to integrate the ridetech sensors into a different system or rerunning all that fucking wiring, making the display pretty as well as paying an arm and a leg for another system is not how I wanted to spend the holiday weekend but its where I am at. If anyone wants a ridetech hoodey and hat let me know there is no way I am gonna sport their stuff anymore no matter if they are local to me or not. Fuck I would even need to repaint my tank to get the ridetech logo off fuck fuck fuck....
Tonight I went out and thought I would give it another try. I went into and measured all the corners, pushed and held the button and I will be damned it programmed! You can imagine my excitement. So then I turned it off, and then turned it back on hoping that it would stay right where it was only to find it let all the air out on the passenger side and puts 75 lbs on the drivers rear and 85 on the drivers front. It doesn't look good and its killing me to have to wait till monday to call ridetech and confirm it. I already have another controller picked out and this one has a lifetime warranty on the hard wired display controller and offers the ability to use your phone if that is what you want. I just hope that the height sensors are compatible and I don't have to replace and rerun all that crap.
