throw out bearing *UPDATE*
F
FullThrottleStangs
hey guys i told yall about how something squeeks when i push in the clutch when i shift. somebody mentioned a bad throw out bearing and a few guys agreed with him. i looked into it and its not an expensive product but i heard you have to take out the transmission to swap it. is this true? any way i could just remedy this without having to take out the tranny?
duff daddy
Re: throw out bearing
If it is the throwout bearing, you do have to pull the trans, no way around it. Do not use an aftermarket bearing either useually the best ones for your application will be the factory replacement.
F
FullThrottleStangs
Is this a weekend backyard job? Or should I take it to the shop?
duff daddy
You can do it yourself but depending on your mechanical skill and abilities it may be better to have a Dealer/Performance shop do it.
duff daddy
You can use it, but I wouldnt use anything but a FACTORY replacement from Ford......
F
FullThrottleStangs
oh ok. i should probably just take it up to the dealership thats 5 min away from my house and get them to replace it. how long would it take and how much am i looking at for the price of labor?
F
FullThrottleStangs
i was just browsing around and i read about how you should hold the clutch in at stop lights, this true?
duff daddy
You cand o the job yourself or take it to the dealer, either way I suggest using the Ford TOB.
As far as holding the clutch in at a stop light, it doesnt really make a difference as long as you dont roll and your not holding the car with slipping the clutch, it wont make a big differece
uncltrvlnmatt
Pa.
You don't have to, but it is less wear on the clutch if you do. Also, if you are going to replace the throwout bearing it would probably be a good idea to replace the clutch since you are there.
F
FullThrottleStangs
Should i get a ford clutch? No aftermarket clutch right?
duff daddy
You can get an aftermarket clutch if you want, but look at yours, mine had 125k 60+ 5kdump passes on it and STILL had some life left lol so look at ours and see what is suggested by who does the repair.
F
FullThrottleStangs
What does replacing the clutch do? Can you feel a difference?
Win
Kennesaw, Ga
Depends on which clutch you go with. If you go with a clutch like i did expect some clutch chatter and a decent increase of holding power from stock. The engagement is harsh but not too bad.
F
FullThrottleStangs
Is it harder to get those "smooth shifts" I like so much?
F
FullThrottleStangs
Oh ok so how much would it be to have the TOB and clutch installed?
F
FullThrottleStangs
See I don't get it. It's such a tiny part how could it possibly mess up and cause something so annoying?
Win
Kennesaw, Ga
Welcome to the wonderful world of Bearings :)
That's what it looks like broken down
