throw out bearing *UPDATE*
uncltrvlnmatt
Pa.
Re: throw out bearing
I figured your car was stock. You will have no problems with a king cobra clutch. They have little bit heavier pedal presure than stock and it bites better. Good luck.
F
FullThrottleStangs
thanks man. ive been dreaming of the day i get to start a build thread for my stang.... :eek:ccasion14:
SRT Handz
Your clutch needs to be replaced.... Go buy one and replace it.
Word of advice, Whenever one part of the clutch system (A bearing, a Clutch Disc, Whatever), you need to replace the whole clutch system.
Since you need to remove the tranny to replace the clutch (time consuming job) is more cost efficient to just replace everything thats down there. Clutches are designed to break, thats why they are so cheap.
F
FullThrottleStangs
so the king clutch comes with everything I need? I also heard something about swapping out the flywheel...
Win
Kennesaw, Ga
You need to take it off and have the flywheel at least resurfaced. If you replace it you could get a Lightweight one if you choose.
F
FullThrottleStangs
ok guys so i was out today and i swung by the ford dealership for a few minutes. i asked for a price for labor on replacing the TOB and he said $650. $650?! thats rediculous. id rather do it myself. king cobra clutch upgrade would be $350 there. i guess im gonna have to do this...
Win
Kennesaw, Ga
FullThrottleStangs said:
Win said:
GO GET IT FIXED ASAP my clutch just Blew UP !!!!!!! :(
erm... your clutch blew up? how can your clutch blow up?
The disc !!!!
javi said:
hate to say it, but i told to you to change it a long time ago...sux thou
Yeah but i was trying to ride it out till i was going to pull the motor out and do it all at once. Can't blame someone for not wanting to do something twice.
BruhBrahBrad
Javi what exactly did you tell him lol, because Im feeling like mine is going out also, and like him Im trying to ride it out also, at least for another 3 weeks.
Fullthrottle---what were you doing messing with a viper, your like 15.
got5.0
Atlantis
yeah, is there a thread on the viper story?
Win
Kennesaw, Ga
He told me when i found out about the Bolt being snapped to get it changed :)
BruhBrahBrad
OH lol... you shoulda listened lol. I dont think mine is anything like that. Just worn.
ryclef331
well then couldnt you just grease it? or is it just not that simple...
Sealed :) not that easy :)
You ought to see the Needle Bearings in Pinon Bearing
There are no needle bearings in a pinion bearing. Its a tapered roller bearing.
To the original poster, IF you're tight on funds, want to learn how to work on your own stuff, have a sucker for a friend or a strong back, and can afford to sacrfice a couple days to do it. You CAN do this yourself and just replace the throwout bearing...provided you don't find anything else wrong in there when you do take it all apart. IF you can afford to do it, replace the clutch. If not, you can get by with just a TOB
Win
Kennesaw, Ga
Sorry i meant to say Pilot Bearing.
ryclef331
Ahh...right you are.
