vac lines
dave1989
ok i broke some vac line and removed the eger and now the car dosent want to idle at red lights the car rund fine does any one now a link for a vac diagramso maybe i could reconnect the 1 thatis causing this
slo1
There is several vacume lines that go from a hole in your passenger fender where the air box is
they are covered in wire loom and go to the smog, egr and fpr they are very brittle start at the egr and follow those lines look inside the loow and more than likely thats were your break will be. If so go to the parts store and there is rubber hose that is just the right size to fix it
