water pump pulley question
infamous209
on my 96 do i need a puller to get the water pump pulley off or do i need to apply a lil force
SRT Handz
you dont need a puller because if you remove the 4 bolts that hold the pulley to the pump it will just come off.
Jetsetter
What? My 00 and 97 pump are both pressed on. You need a puller to apply pressure on the shaft and then the pulley will come free.
duff daddy
My 96 pulley was bolted on to teh face of the pump. Just took a little to "massage" it off.
I
infamous209
well mine took a little force but it came off and the water pump is a BIOTCH to get off, heavens to betsy i was gettin frustrated!
Twista
What are you trying to do. I ended breaking the waterpump itself trying to remove it for the pi swap. Ended up buying a new one lol.
Are you doing the pi swap. If so the waterpump nipple is going to be the pain of this whole install.. after that will be bolting the back bolts to the back of the block.
I
infamous209
no water pump was making that lil squeel so i thought i should take care of it before it went out
junior897
I figured out the easy way after I messed up the water pump nipple. I got an old wood chisel, and used it to cut off the bad part then just pulled it out with pliers. The water pump on the other hand was no fun, but I did get a new screwdriver out of the deal.
JDwhite98gt
When I did my first swap I never touched the nipple I just used some rubber hosing and hose clamps, cut some of the pi metal hose off and voila, it worked and never had a leak.
