weight of 2v gt parts
Green Goblin
i'm only 170 lbs, with about 10% body fat. so i'm putting this gt on a diet. i added an on3performance 70mm turbo kit and more than 250 rwhp and more than 300rwtrq. also the turbo kit came with a pipe that replaces the stock h pipe with cats, so not sure on that weight diff. replaced stock exhaust manifolds with upr shorty headers don't know those weights. deleted egr and sure that is about only 1 lb. installed front coil overs. not sure on the weight of the stock k member, arms, springs, or the tubular kit. repaced the rear shocks and springs with coil overs. replaced stock rear upper alower control arms with some bmrs. replaced the stock drive shaft with an aluminum 1. don't know the weight of those, but that the alum is about half the weight. fog lights are gone, but they are less than 1lb. removed a bunch of things, but haven't had a chance to get the weight on them yet. trunk panels, carpet, spare tire, jack, etc. entire mach 460 system. leather rear seat, top, bottom, and seat belts. haven't found replacement yet, but leather front driver seat with electric track. pass seat with track. no weight yet, but driver and pass air bag, plus module and bracket. next dog bone off of rear end housing, cruise control module and cable, abs module to be replaced with billet union block. power steering to be replaced with manual rack. deleted wing off trunk along with gt and ford emblems.
leather rear seat top, bottom, and seat belts = 39 lbs
leather front driver seat with electric track = 59 lbs to be replaced with prob something around 20 lbs with track
leather front pass seat with track = 42 lbs ...
entire mach 460 sterio system = 34 lbs
wing off trunk = 5 lbs
duff daddy
as per frank...on an sn95 ont new edge...
Drivers seat Leather 48 lbs
Passenger seat Leather 38lbs
Rear seat Leather top half 30lbs
Bottom Rear seat 15lbs
Sounds deadening (Remove w/Torch and Scraper) 45-50 Lbs
Under Carpet Insulation 20Lbs
Door Panels 8Lbs Each
Extra metal out of front bumper (Center) 8Lbs (Kept most of it)
Front Sway Bar w/links 13.5Lbs
20Lbs going to front coild over setup.
20 Lbs going to lighter front seats with manual sliders.
CD Player Head Unit 5 Lbs
Window Motor 8Lbs
Rear End Dog bone 10 lbs
metal plate under steering column 3.5 Lbs
Wind shield washer tank 1.5Lbs Empty/8Lbs Full
Passenger side air bag 9Lbs
Drivers side air bag 3 Lbs
Air bag sensors and module 3Lbs
Hood latch w/cable etc 2-3Lbs
Cruise control (In Fender) w/cable 2-3Lbs
Glove Box 4lbs
Trunk Lining with spare tire cover 14Lbs
Spare tire 25 lbs
Jack and tire iron 8lbs
Smaller battery 10Lbs
Mach 460 Amp Rack 6Lbs
Mach 460 Speakers 2.25 Each
6 disk changer 2Lbs
Rear Seat belts 5 Lbs
Sun Visors with harness 2.5 Lbs
E-Brake Assembly w/cable 7.5 Lbs
Black boxes behind rear tires w/brackets 3Lbs
rille insert and Radiator cover 2 lbs.
Mott bar and bumpstop bracket 9 lbs.
Fog Lights and brackets 6 lbs.
Rear Bumper support brackets 6 lbs
Factory Spoiler 9 Lbs
Strut tower brace 8 lbs
Complete Front Bumper support 17 Lbs
Quad Shocks w/brackets 8Lbs
Rear Sway Bar 8.5Lbs
Convertible K-Member brace 17Lbs
Firewall blanket 15 lbs
Door Bars 8 lbs
Dead pedal 1 lb
Tailpipes 20 lbs
Evap Canister 5 Lbs
EGR and DPee 4 Lbs
Rear Bumper 25 Lbs
Convertible top pump/motor/cylinders 12 lbs
A/C Complete 30 Lbs
ABS Pump Delete 14 Lbs
99-04 Brake Calipers 10 Lbs Vs. 14 Lbs 94-98 style
wiper motor and linkage 6 lbs
Heater core/A/C box/ fan 19 lbs
Bumper suppor mounts w/wind deflectors 5.5 Lbs
Stock A-Arms 30 Lbs, Tubular A-Arms 15 Lbs
hydro-boost and master cylinder assembly 17lbs
Power steering pump 10 Lbs, Delete pulley 1.2 lbs
Power steering lines and Res 5.5 Lbs
lock mechanism,window motor,wiring harness 12 lbs
Gut underside of Trunk, Trunk will weight 20-25Lbs
Few Lbs Misc Nuts/Bolts and Removed Metal.
G
Green Goblin
awesome. thanks for the info. trying to have 2 light seats, interior trim panels, carpet dash and console without airbags and radio, but keep ac bc i live in the hot ass 504. trying to get it to about 3200 with me in it and some gas
Pennywise2
Good luck with your On3Performance turbo kit they are well known for their problems.
duff daddy
MAKE ONE THREAD ON THE SAME TOPIC AND CALL IT A DAY IM LOCKING THE OTHER ONE!!!! AND MOVING THIS ONE.
Jerry santos
