what cam is better
94-5.0GT
which cam should i go with a comp xtreme energy 274HR or a Anderson N-41 or FTI Cam(302ci-311ci,its closer to a 274HR cam)
stock 90 bottem end(trw forged pistons), gt40p heads gotta get .550" lift springs still and a typhoon intake. also going to be sprayin it too
Steven
SC
project94 said:
^^^^^ no he is asking which cam would go better with his setup.
and again how would we we..
Paul said:
Are we supposed to guess the specs on these?
+2. I like option blue, it matches the car better. lol
94-5.0GT
i had a post on corral and someone pm me about this fti cam and all he said was that its close to a XE274HR cam. i pm'd me for specs, i will let you know. an all three of this cams are about the same price. but im afaid that im going to have some valve to piston problems due to the lift of the cams. what is the most i can go? I heard .520".
Paul
Duration and valve event timing are more critical on PTV clearance than lift.
94-5.0GT
lobe lift is .3150"
gross valve lift 1.6RR .5040"
1.7 .5355"
1.72 .5418"
duration at .050" tappet lift is 218
lope sepration is 111
would that clear stock trw forged pistions?(or is there some stuff im forgetting)
Paul
You only posted specs for one cam, and didn't tell us which one. How are we supposed to pic which one is better?
LAFENATU
Agreed.
Valve lift is important but you want to know when they are opening.
I wouldn't be to concerned about lift until your around 230+ duration.
Regardless though, ALWAYS check first. Clay the heads and make sure they clear. Also make sure you get the proper pushrod length.
.02
