joemomma
- Joined
- Dec 9, 2020
- Messages
- 1,263
- Reaction score
- 769
Yeah man the pollen here is insane.
The block is a huge lump of metal and has very low resistance. A ground on either side of the engine is fine as long as it's clean, tightly fastened on both ends, is gauged according to the total current passing through, and the chassis side of the ground has a lot of meat to it (not a thin piece of sheet metal).Did you clean the connection prior to this, sand the paint/dirt off? when I added a ground to mine, I used one of the bolts that holds the starter on. NOTHING in the car draws current like the starter and it never made sense to me to have the ground on the ther side of the block on the 5.0 at least. It is also easy to get to with shorty headers on.
Well, what did it make? Did the springs get you all the rpm you were looking for?Picked it up from the dyno shop , drove it the couple hours home . Car pulls way harder and actually revs up now . The gm iac made such a difference the car idles so good now no surging at all or hanging idle .
462/474 at 12lbs car runs way better the gm iac made the car run like a stock car it pulls way harder above 5k rpm now , I’ll do a draggy later and see what my trap speed is . Dyno numbers don’t mean much to me trap speeds more important to me . I’m going to grab another shortblock throw some nice pistons in it with my Victor jr heads . I’ll drive the car later , I’m headed to the dealership this morning to trade my truck in .Well, what did it make? Did the springs get you all the rpm you were looking for?
Can you tell me more about the GM adapter. Or maybe you posted more info elsewhere on the forum?
Did you buy the Accufab adapter? Which option (old or new style GM IAC)? Is there an adapter for the plug, or did you need to cut and solder on a GM connector?
Did everything run ok after the install, or did you need to tune it? Or did you just happen to be getting it tuned when you added it?
I adjusted the passenger door striker. Now it closes so nice and crisp. Nothing better than a crispy closing door.
But, can it haul a bag of groceries? Huh, huh?
