what timing set are you running ?
Pure84GTT
what timing set are you running ? what did you like about it ? my last 3 motors I went with a basic cloyes unit and had nothing bad to say about them.. but they are rather basic
Win
Kennesaw, Ga
He means which gear and chain.
i am going to be running a simple comp cams set with a double roller chain. Just a simple set.
Dr.Scientist
What would be a special, or fancy timing set? And what are some of the disadvantages of the higher end units?
Addermk2
http://www.summitracing.com/parts/CCA-7138/
It was kinda a PITA to get the thrust bearing countersunk for the screws, but I liked the fact that it had a roller bearing, instead of the gear riding against the thrust plate itself. This piece was recommended by my cam designer.
Paul
In my fancy motors I ran a Rollmaster billet double roller. My normal new wimpy motor just has a Cloyes.
Paul.
Paul
That's the one I ran in my fancy motor. To my knowledge, it is manufactured by Rollmaster for Comp Cams. Nice piece.
Dr.Scientist
Addermk2 said:
youve got to have some hardcore springs to stretch a chain...
I've taken apart a couple mid 90's pontiacs v6's that had finally gotten too much slack in their chains. This happened over about 150k miles though. I was just wondering if these better chains will do that. Course most people usually blow up or change out their engine by then. When it comes to this performance type stuff.
evilcw311
Most Evil Member!
Louisville, KY
comp cams double roller as well...............wait you mean noones rolling with a noisy arse pete jackson gear drive??? lol
always loved the sound of those, but it would give you a headache after a while!!
