Window Help!!!
Cali95gt
i have a 95 gt. the drivers side window seems to slide backwards and forwards. i can't raise the window without guiding it by hand. please any help would be great.
GDTrumbo
Nashville, TN
Remove the inner door panel/moisture barrior and inspect the window regulator. The OEM parts were a little weak and sometimes will actually tear one of the staped metal arms. Mine was $126 from Ford for new updated piece. Yours being a '94-'95, the part is a little different and may be higher. Don't bother with the salvage yard. You'll end up in there again.
GT
C
Cali95gt
i looked at it and the little ball that guides the window on the track is constantly popping of the track. is this a easy fix or do i need a new piece like stated above???? help it's getting hot
GDTrumbo
Nashville, TN
Being a '95, your window mechanism is slightly different. Is this a power window unit? Is this "ball" actually a roller or a small wheel? Is this ball attached to the scissor arms of the regulator assembly? Pictures possible?
GT
C
Cali95gt
its a power window. i'm pretty sure its a little wheel and it has come off the track. when i push it back on it stays for a while but come back off. i may be able to get some pics. lets wait for the morning. but help!!!!
