Window is not working
94 DropTop
my driver side window is not working. all the others work just fine. When i hit the down button i here a clicking nosies when i push the button and then another click about 1 sec after i let off the button. when i push up i didnt here anything.
94 DropTop
it was working just fine on the way home i dont see how somthing can change in 5mins
94 DropTop
do all the windows run off the same fuse? O btw im hearing the clicking in the door. i might just take the panel off tonight.
AaRoN
King Post Whore
i'm not sure if they all run off the same fuse... :google2: maybe......i'd take it apart and look at it...maybe it's something simple :dunno:
94 DropTop
its a ford nothing is simple im going to grab somehting to eat and then go out and check the volts on the motor. where are the relays for the window btw?
94 DropTop
well the clicking is coming from the relay or solonoid in that is mounted on the back part of the door panel. So im guessing that is the problem. what do you guys think?
BOS-94-003
I'm thinking the gear is stripped on the motor or the motor itself is bad. The circuit board could be bad also or something came unhooked. Let us know what you see when you get the panel off. Alot of possibilities.
94 DropTop
look up. the clicking is coming fromt the realy breaker thing mounted on the door panel itself.
94 DropTop
not really its coming from this lil black box thing in the door panel. I dont know what it is but its coming from it.
94 DropTop
well i found out that the lil black box i was talking about is the express down module. I know if it isnt pluged in the window wont work. i guess ill have to call ford in the morning. So how do i test if the motor is getting power? the hanyns manual sucks and does give a good pic. do i unplug it and see if there is power getting to the plug? How much do motors run at say autozone? How hard are they to change out?
AaRoN
King Post Whore
yeah unplug it and you should be able to hook a multi-meter to it. power window motors are probably gonna be $$
94 DropTop
well it looks like the motor is getting power so im fucked, i just checked autozone.com and motors are about 80 bucks. how do i know its not the regulator the new motor dosent come with one.
AaRoN
King Post Whore
if the motor isn't getting power...i'd say it's either the regulator or the bushings :dunno:
