Winter Builds 2013!!
03DSGGT
SN95 Supporting Member
Akron, Ohio
Continuing my Teksid build. My plan is to have all of the parts bought by the first of the year, then save up over the rest of the winter to have the block machined, sleeved, and everything balanced and shortblock assembled by spring...we'll see...
KillNThrill24
KillNThrill24
Cleveland Ohio
Sounds like some cool stuff going on this year fellas hoping to see some build thread updates!!
As for me... Currently unsure. I'm at a job making a good bit more money than my old job, so I'm considering pulling the trigger on a new shortblock. But that all depends on if the trans/rear end/everything in between holds up.
Here's the list of problems I can think of off the top of my head that I would really like to fix:
Heater core needs replaced
Strange clunking from the rear end area, also threw the abs light on
Front main leaking oil pretty bad
Diff leaking fluid from either the cover or breather cap
Front rotors warped causing pulsing in the brake pedal
A/C works when it wants to, and works damn good, other times it's dead and engine pulses when turned on
Battery is either on it's way out or something is staying on causing it to die within 24hrs
I know there's more shit I'm missing lol but that's the basics. You'd think as much mula as I've put into my car it'd have less issues. O well. It's the name of the game we all play
