blown97stanger said:installing cams...may have bent a valve. forgot to rotate the crank. if that is the case, im pulling the whole motor and builing a beast. I'll keep ya guys updated
Did you try and install a follower in the wrong position?
You might be fine, compression test will tell you whether you bent a valve or not.
