winter gameplan...what do ya think?
massacre
blown97stanger said:
installing cams...may have bent a valve. forgot to rotate the crank. if that is the case, im pulling the whole motor and builing a beast. I'll keep ya guys updated
Did you try and install a follower in the wrong position?
You might be fine, compression test will tell you whether you bent a valve or not.
97stanger
97stanger
whew, so i think I'm okay on the valve. Yeah, I'm going to have to really make sure this tune is dead on. I'm going to need all the reassurance I can get with this his of hp/tq on our crappy little stock rods.
chaz
Draper UT
DropTopPony said:
Did you buy the meth kit yet? Not sure if that would benefit you all that much because you have an intercooler
Not being high boost I would think that meth kit will only add 10 to 20 HP with a conservative tune I dont see this motor goin much over 450, if it does i dont know how long it will last.
97stanger
97stanger
450rwhp through a built auto, 3500 stall, and 4.10 gears though. keep that in mind. If i were a manual, it would probably be close to 475-500rwhp.
97stanger
97stanger
after talking to the Snow Performance rep he thinks I will gain in the 30rwhp range. I mean, im not running THAT low of boost. I sometimes see 13-14psi...this meth kit will be like running 116 octane
96GTPlanB
