WTB: DS Door Cup, Manual windows
ChadH95GTS
Cincinnati, OH
Would prefer a black door cup(the thing you yank on to close the door). Gotta be a manual window one. Mine has a tab broke on it and it's down right annoying!
if worse comes to worse I can tell you how to fill in one with switches, or could do it for you if you need.
it would really not be that hard to fill the holes. Just throw some tape on the top, fill it from the back and then sand till its smooth and paint it.
framda
Naples, Fl.
Scott, Any cure for one with a broken upper tab? The one that pushes into the door panel?
I have been considering expandable foam. Just pull the cup out, put some foam between the door panel and where the cup would go and then put the cup back into place. IT would take up the space that is empty between the panel and the cup and should help for a little while but it would be temporary. But you could use that to figure out how much space is in there and then put some wood or something more solid in there to take that space up.
