Want To Trade WTT my solid rear axle for a cobra IRS
martinbaca18
The SRA is from my 2001 Mustang GT. I'm from Los Lunas, New Mexico. It will be a full trade for trade.
evilcw311
Most Evil Member!
Louisville, KY
You should probably post what info you have on the rear end and why it's a comparable swap
hell I would love to swap a solid for an irs. people do that? I always figured when/if it came time for that I would just be stuck with the stock axle.
Cpotts13
Biloxi, MS
No one swaps a $200 stock SRA for a $1600 IRS. NO ONE.
Unless of course the SRA is built with top notch parts, even then people still want cash on top.
martinbaca18
martinbaca18
The SRA is good for drag racing so it won't break easy when you make really good traction off the line. Or that's what my ignorant ass says. I'm always wrong on this forum. Next post after this dersevers a cookie for info I don't care about
MAN...you are wrong! No clue why either! Figured I'd be the fill in...lol
yes it is stonger for the strip but with that being said I have never known anyone to swap an irs for a sra. The only time I have seen IRS come up for sale it was out of a wrecked and parted out car. On the same token the old pushrod is easier to tune and parts are cheaper but I would not expect to find someone that is looking to swap a coyote motor for a pushrod...
Cpotts13
Biloxi, MS
Yes you are correct however they are very weak in stock form with the 28 spline axles a diff.
:thumbsup:
I want a irs so bad, but with going prices at $1200+ idk....
evilcw311
Most Evil Member!
Louisville, KY
Am i still nots seeing the build specs?!? If no then I'm assuming it's a stock rear end with the same weak 28 splines as an irs.
Even fully built sra's usually have to toss a lil cash in to trade.
Wichers123
Covington, louisiana
So much bad information on IRS. Lol the 99-01 is weaker than the 03-04 rear. I believe (as my 03 rear has 31 spline axles) 03-04 have 31 spline axles and the shaft size in the center is much larger than the 99-01. The weak point of the IRS is the rear cover and mounts. My IRS has all the urethane bushings bump steer kit and mounts and cover and it came out to about the same as a built axle if you included the price of the axle assembly itself. I say my car IRS transfers harder and leaves straighter than Sra that was in the car. And then can be lower and function correctly and ride better.
chris91
Cincinnati, OH
I've seen quite a few guys trade their stock IRS off for a SRA with just a set of gears, aftermarket LCA's and a decent exhaust. Shit, I could trade right now for one but I don't want to sacrifice my gears and go to a 3.55 right now. I do have a Bassani Exhaust though which definitely sweetens the deal.
And people paying $1600 for an IRS better get some Vaseline with that. The going rate is $1000-1200 around here and that includes an exhaust.
Cpotts13
Biloxi, MS
Shit i would trade my mach rear end (cobra sized brakes, 3.55's, j&m lcas, borla catback) plus cash RIGHT NOW.
I just traded the solid axle out of my 98 for an 03 IRS. I had to come off a little cash and pull it myself but it was well worth it. IRS had all poly bushings already.
Canaryonvskf’s
