1995 Cobra Upgrades
evilcw311
Most Evil Member!
Louisville, KY
Does your innovators West balancer have the magnetic points in it for use with a crank sensor?
kb1982
kb1982
Kentucky
Naw it doesn't have the flying magnets in it. I debated that option before buying it, but decided if I ever go to coil on plugs, I would move to a 36-1 toothed wheel.
Sent from my Z962BL using Tapatalk
evilcw311
Most Evil Member!
Louisville, KY
The one I have has them. I already got my cam sensor so now I’ll just need the coils which I’ll probably get ls coils.
kb1982
kb1982
Kentucky
Got a few things in today. Mainly a complete fuel system from Behind Bars Racecars. Should have plenty of fuel for the switch to E85 with this setup along with 95lb hr DeatschWerks injectors
Sent from my LGL83BL using Tapatalk
evilcw311
Most Evil Member!
Louisville, KY
I’m not familiar with them. How’s their kits and prices compare to glens?
kb1982
kb1982
Kentucky
I thought long and hard about the18 gallon intank setup
98snakehorse
Southeast, IA
Im wondering if they could install different sized feed and return line fittings. Looks like they are using -10 I would need a -8 feed and -6 return. Regardless the price is sure right
kb1982
kb1982
Kentucky
Its goes from 10 out of the tank to prefilter, pump, filter, then all the way to the engime to a y block that splits to 8 and feeds the rails in the front. From rails to regulator to rteurn is all 8. And yes you can get whatever fittings you want. Just give him a call or an email.
kb1982
kb1982
Kentucky
Havent got much accomplised lately due to workand the cold weather. I did get fuel railsand injectors installed along with a few odds and ends. Filled the motor up with oil and primed it, and not long afterwards discovered an oil leak. The new oil pan had a very large pinhole in one of the welds. Talk about quality control. I also found out it is near impossible to find the wiring harness side tps connector for a foxbody. Easy fix, buy another new tool. Anything that needs a new connector will get weatherpack connectors.
Sent from my LML713DL using Tapatalk
do yourself a favor and save that pic somewhere or write down the pin-out on that harness somewhere. I have been swapping/adding harnesses on mine for a while and at first thought there was no way I would forget this stuff. Years later I hardly remember it....
