A little bit of 5.4l adventure. The valve covers were leaking oil, both sides, which im not surprised cause the gaskets are orginal...lol. Rumaging around in my parts selection I found a set of gaskets in better shape.
Here is the adventure!
The driver valve cover was extracted first, but not untill 3hr later....lol. Nearly all cover bolts were removed by extentions and swivels. The last bolt was not accessible from the top. Hydraboost prevented any possibility to mount a socket. Let alone and extention.
Going under the car and snaking my arm up next to the steering shaft with an 8mm wrench, I managed to work out the bolt. Cool!
Not so cool...the cover wouldnt easily come out. The clutch cable and once again the hydraboost/brake booster (whatever) prevented any room for the cover to clear away from the cam towers.
Removing the clutch cable and then removing hydraboost nuts from under the dash allowed for the booster to be moved away from the firewall and move ever so slightly away from the cover allowing enough room to be vigorously mean to the cover for extraction.
Now after doing so, caused a little bit of damage to the inside of the cover were the hang up spot was. Not a big deal! The damage area could be cleared away by grinding off with a dremel or file with no affect to the cover. By doing this allowed the cover to slip right on in much easier than extraction. Now if only the new gasket will stay put on the cover and stop falling off, I can get this crap done!
