Turbulence
I am hoping to get some help from the wise, and talented members of this forum with tuning my 94 cobra now that I have installed a turbo. I will do the best I can to include all that I have done so far, and any suggestions would be great. Here is what I started with....
but it looked like this where it counts...
and it was tired, and beginning to show signs of being ridden hard and put away hot and wet so I got brave, since I am really just a weekend shade tree guy, I was worried about what had to happen next....after getting the top end off, the right side looks pretty normal, but the drivers side looks cooked by comparison.
Turns out what I took for rings going bad, or valve seals allowing bad oil bypass, was actually a terribly leaking intake manifold gasket, and a really clogged up coolant system. I had the typical broken bolts despite being "extra careful" on both the timing cover and the intake manifold, as well as the heads. It was really overdue for some love. I had traded a FZR1100 for this car, and other than the wheels, and a few other little upgrades, I hadn't had to do much to it, except fluids and such. But my good friend has a fox with an 88 MM turbo, and he suggested, "Why not go boosted"? Famous last words I think.
I had the heads gone through at a local machine shop for a great price. GT40 heads flow pretty good, so I didn't change them. Aims Machine did a great job. The rotating assembly didn't really show any wear at all, amazingly, so after new total seal rings, and mains, and some light crank polishing, back together it goes.
I wanted to build my own headers and basically assemble a turbo kit from spare parts. I had a bunch of pieces, and I used these knock off headers as a guide to location. These really will not work if you intend to keep Alt. in factory spot, or basically anything else factory. I wound up using them as TIG welding practice.
I will post some more later. Thanks for looking.
