95 mustang gt intermittent problem
supastang95
I have a 95 gt and put the trick flow street heat kit on the car along with 24 # injectors...after i did this the car would never run right, i can be driving down the road and the car would just die. also, i could have just got done driving the car turned it off to go inside, and come back out to go sumwhere else, and it wouldnt start. I bought a SCT chip for it thinkign it would help, it did for about 3 days, then a check engine light poped up. so i changed the IAT sensor, and it started up fine, but an hour later when i went to go sumwhere, it wouldnt start agin. ANY suggestions?
[attachment deleted by admin]
prstang
If you have the stock distributor, you may want to check the stator. That problem drove me nuts for a while. Please have your cel codes read before buying parts!
Win
Kennesaw, Ga
yeah i had a couple stangs i worked on at my shop that i ran into the stator being bad on the dist. i would say check it.
supastang95
it not the original distributor, but i did buy a new one that is stock....it was just a remanufactured one, maybe thats the problem.
